Cause 1
Door Latch
The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
Parts
Door Latch for your WhirlpoolDishwasher
Door Latch - Part # 3198192 Mfg Part # W10619006
RepairClinic Item #3198192
Door latch *Part has been redesigned by the manufacture
$25.64
Quantity:
In Stock ›
Same Day Shipping
Order by 8:00 PM ET, this part ships TODAY!
365-Day Return Policy
Return any item for any reason within 365 days of placing your order.Find out more »
Total: $25.64
ADD TO CART
Cause 2
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If there is a problem with the main control board, it might not send voltage to the dishwasher, causing the dishwasher not to start. Control boards are often misdiagnosed—make sure you check more commonly defective parts before replacing the main control board.
Parts
Main Control Board for your WhirlpoolDishwasher
Main Control Board - Part # 2312646 Mfg Part # W10479764
RepairClinic Item #2312646
Electronic control
$143.80
Quantity:
In Stock ›
Same Day Shipping
Order by 4:30 PM ET, this part ships TODAY!
Total: $143.80
ADD TO CART
https://www.repairclinic.com/RepairHelp/...
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
