Aller au contenu principal
La version Wi-Fi de l'iPad Air d'Apple, numéro de modèle A1474. Disponible en gris sidéral ou argent, il emploie le processeur A7 personnalisé et est livré dans des configurations 16, 32, 64 et 128 Go.
299 questions Voir tout
Lightning Dock Connector no longer accepts charging cable
The Ligntning Dock Connectior in my 16GB iPad Air (1474) will no longer accept the charging cable. When inserted, it never "clicks" into place and pops back out again.
The cable works fine with my iPhone 5S.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
For what it's worth -- it turns out my problem was apparently common to the charging port on the iPhone -- pocket lint!
The exception was in my case, the lint was deposited on the SIDES of the port, not the depth.
Cleaning out the depth didn't do the trick, but when I scraped the sides of the port, the "stuff" came loose and could be blown out.
Primary tool -- a plastic dental-floss pick! Just the right size and stiff enough to scrape with, but not too stiff to bugger contacts !
(Having been retired for 12 years now, my days of micro-soldering are beyond my field of vision. Thanks for the pointers.)
par
Ajouter un commentaire
1 Réponse
Solution retenue
You need a new charging port. Downside is it needs to be soldered onto the logic board. I know @refectio and @teetop do board level work
Indice 3
Ajouter une réponse
irmagill sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 153
