Aller au contenu principal
The Huawei Honor 8 is an Android smartphone released in 2016 that features a 5.2-inch 1080p display, 4GB of RAM, dual 12MP camera sensors, a fingerprint sensor, and a USB Type-C port. Model : FRD-L04.
48 questions Voir tout
Phone won't turn on after drop.
My Honor 8 won't turn on after drop. Only red LED lights while it is plugged in charger. Can you help me ? Phone is on first sight not damaged. Could it be display issue or some pins inside just disconnected? When I connect it to the PC it shows up and disconnect and this repeats.
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire:
I have the same problem but when i press the power button for a long time it shows "Honor" and it dies again the screen lights up for a second
par
Ajouter un commentaire
2 Réponses
Hello! An unprotected drop to a phone is likely fatal to your beloved device. Luckily, by your description, it only appears that your display and display and connection components are damaged. You can easily get this repaired at a professional repair shop.
Indice 0
1 commentaire:
So I need to replace whole display? %#*!^@. Thanks for your reply
par
It sounds like a component of your LCD display was damaged from the drop. I suggest replacing the LCD display on your device, which you can do by following this guide.
Indice 0
Ajouter une réponse
Timotej sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 7
Total : 1,060
