Can I cut the charging port wires and attach a different charging port
I have half the wires out already that's bad the other half is good
so, essentially the answer is a hypothetical yes.
however, you would need the pin out of both the original, and new port in order to do this procedure.
in doing this, you would also need to make sure the new port fits the jack that you are looking to put into it.
As long as all of the nodes match up, without shorting, or getting cold, then you should be able to have the current run through properly. (i just swapped out a charge port in a lenovo laptop with the head of different charge port, by this procedure)
there are a lot of variables of the like posted above, and i would honestly suggest just purchasing the component you wish to change as a whole. this is a more commonly successful repair than splicing.
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 180
Which part? The charging cable or the port on the laptop?
par Cameron
