How do I replace the seals in the Thermoblock?
How do I replace the seals in the Jura Avant-garde S8 Thermoblock? The halves need to be separated.
Look here - but you need to know some german words, or just use Google translate. The right guide is called "Revision des Thermoblocks"
This is wonderful! On page two of the guide, a tool that looks like a Nut Driver is used for the center bolts. My Thermoblock looks like it uses hex-head bolts and I am not sure I can find a thin Nut Driver to fit in the hex-shaped recessed hole. I will search.
The two bolts should be normal ones of 7 mm. The outer screws should be a Torx ( or Allen, don't remember?)
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 132
