Spin cycle loud but works
yesterday heard a load "thunk" while spinning with a heavy rug in it. It still spins but is VERY load internally. Vibrates some but not crazy, just noisy.
Cause 1
Tub Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing as an assembly if the manufacturer offers the components together.
Cause 2
Tub Seal and Bearing Kit
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. If the washer is noisy during the spin cycle or is leaking from the bottom of the tub near the transmission, the tub seal and bearing are likely defective. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing the outer tub and bearing at the same time.
Cause 3
Rear Drum with Bearing
The rear drum has a bearing or bearings in it to keep the inner tub spinning smoothly. If the tub bearing system is defective the washer can become very noisy. On some machines bearings are sold separately from the rear drum, however we recommend replacing both the outer drum and bearing as an assembly if the manufacturer offers the components together because removing and pressing in the new bearing can be exceptionally difficult. Be aware that replacing the outer tub and bearing is also not easy and can be very costly.
I would check The drum. If there is any movement of the drum Inside the shell. That is indicating. The bearings are bad. If you spend the drum by hand. It should be very smooth. If you feel any hesitation That is a bad bearing set. For the drum. And that is very expensive to have a repairman do. And is also very complicated. 2 fix. In a DIY situation.
I just bought a kenmore HE 4.3 capacity on my first 3 loads when in spinning there is no noise and in the 4th load the 5th load and so on the washer is noisy and vibrating in the spinning cycle is this washing machine defective since I bought it 4 days ago pls let me know thank you
Dernières 24 heures : 1
7 derniers jours : 17
30 derniers jours : 67
Total : 10,382
