Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
"Unable to join WiFi network" How can I fix this?
So, my iPod Touch 1G just arrived today and for some reason, the WiFi has a weak signal and it says "Unable to connect to the network". Does anyone know how to fix this?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 solution
Unplug and plug in router. Move close to the router (try this step first). Restart iPod. If all else fail try full erase.
Update (01/13/2018)
Is the iPod used? Or new? A used iPod might need the Wifi antenna replaced or it could’ve come disconnected. Most of those are little (coax) cables but they look different in a phone or ipod/iPad. I wouldn’t suggest doing this yourself because iPods are the hardest Apple device to get into unless you like soldering. Sorry for the late reply. I hole this helps if you’re still having the problem
Cette réponse a-t-elle été utile ?
Indice 0
Commentaires:
Everything i tried failed, even the reset. What do I need to fix?
par
Ajouter une réponse
superlions16 sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 287
