Aller au contenu principal
Modèle A1297 / Processeur Core 2 Duo à 2.66, 2.8, 2.93 ou 3.06 GHz
998 questions Voir tout
No Backlight; replaced screen
MacBook Pro 17 A1212 (2.33 Core 2 Duo)
This MBP17 had display issues and under AppleCare I had the screen and logic board replaced twice. Now after the AppleCare is over and the 90 day warranty on those repairs is out of date, the backlight has gone out. I can see the image of the log in screen. I removed the entire display assembly and replaced with a A1151 display assembly but same results...no backlight. My guess is that this since the inverter is inside the display assembly that the issue lies in the logic board...can anyone confirm this? Not sure if this is related but the backlight on the keyboard still works.
Répondu ! Afficher la réponse J'ai le même problème
Indice -1
Ajouter un commentaire
1 Réponse
Solution retenue
Replace the inverter. LCD screens require the use of an inverter to supply power to the screen’s back lighting. Here's the part: MacBook Pro 17" (Model A1151/A1212) Display Inverter
Here's how to install it: Remplacement de l'onduleur d'écran du MacBook Pro 17" modèles A1151 A1212 A1229 et A1261
Image MacBook Pro 17" (Model A1151/A1212) Display Inverter
Produit
$69.99
Indice 2
1 commentaire:
Ordered the part from iFixIt and replaced the inverter. Still no backlight. What do I do next?
par
Ajouter une réponse
Alan Cook sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,849
