Dead. No longer turns on.
My 2.26 white unibody won't turn on. I connect the magsafe and the light on the magsafe connector goes green, then turns to orange. If I press the power button, the magsafe turns green immediately, then after 20 seconds turns back to orange.
I have tried a replacement used logic board which was sold as working/tested, but the behaviour is exactly the same as before.
MacBook Unibody (A1342) 2.26 GHz Logic Board
I'm at a bit of a loss.
2 commentaires
There's not much to work with here. Do you get any other symptoms, any other lights or sounds, would you give a history, what have you tried?
par mayer
Completely dead. Just simply didn't turn on one day. Unibody has no other lights than one on the magsafe charger, which is green when connected, then turns to orange. When the power button is pressed, the magsafe turns to green immediately, then turns back to orange after 20 seconds. No other symptoms, gives no other signs of life, no fans noises, no startup chime.
I have tried a replacement logic board.
par Rossinator
