Aller au contenu principal
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Questions au sujet de 607 Voir tout
Tearing apart my iMac 20" system to replace graphics card
I need to replace my graphics card.
We are stuck at pulling out the plug to the on/off button from the logic board. We can’t get it disconnected.
Aside from it hurting fingers. My husband tried to disconnect it & he said it is in there way to tight. He thought about pliers, but is afraid they may hurt something. He said there’s got to be a tool that can be used to pull it apart.
The spudger & prying tool are too weak, I’ve tried it. They break or tear. Any suggestions on a tool that can be used?
It’s on a table covered with a towel. I’m worried my cat will jump up there. Not that he will deliberately hurt something, but that he may consider it a great spot to nap. He’s 16 lbs of muscle & not careful!
Répondez à cette question J'ai le même problème
Ajouter un commentaire
Batteries pour ordinateurs portables
Une réparation facile pour un gain en puissance max.
Acheter maintenant
Acheter maintenant
1 réponse
If the connector won't split apart the only other option is to carefully mark the cable wires (polarity) and cut them making sure you have enough length so you can solder them back with some shrink tubing covering the splice.
Cette réponse est utile ?
Ajoutez une réponse
ladycerridwyn sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 37
