Aller au contenu principal
Annoncé en mars 2015, puis commercialisé le 10 avril 2015, le Galaxy S6 est le prochain flagship de la série Galaxy. La version avec un écran incurvé est connue en tant que Galaxy S6 Edge.
487 questions Voir tout
solder old nand flash on new motherboard
Hi,
My samsung galax s6 took water damage, but I want to retrieve the data on it. I already tried to replace the battery and usb connector unit. Both didn't work.
My last resort would be to buy a cheap 32GB mortherboard on aliexpress. And remove the 128GB nand flash from the broken phone and solder it on the 32GB motherboard.
1. Will this work in theory?
2. Can this job be done by someone with next to none soldering experience? btw, I dont care if i will screw up, because I see it as the last resort anyway.
3. Or do you have other suggestions to get the data back, which are not expensive.
Thanks
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Is there any way to fix the water damage?
Electronics Water Damage
Indice 0
1 commentaire:
Thanks, I already cleaned en submerged the boards with isopropyl alcohol. I couldnt really reach the processor, nand unit etc. though, since they are under a protective shell.
par
did you already try this? I'm in the same boat. I will try this today a let you know what happens
Indice 0
1 commentaire:
Did you have any luck with this?
par
Ajouter une réponse
Mar Do sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 375
