Aller au contenu principal
Here are the repair guides for Xiaomi Redmi Note 4X
Questions au sujet de 34 Voir tout
Why the mi note 4 isn't Powering back on?
a night ago, the phone was completely fine, and battery was less so i decided not to overcharge phone the whole night, but the next day when i put the phone on charge, it didn't powered back on. and it was stuck on the "mi" logo and probably nothing helps as it was probably stuck there for around 3 hours and then i started to lose it and i used this method where someone pointed out that i should use some more/less output power adapter to charge or use my laptop to charge the phone, their phone jumpstarted and mine didn't, this was to try and get the phone to power back on, but no help again. someone also suggested me to use fastboot during the charging and during the usb connection to laptop. but laptop isn't able to detect my phone, so thus, the phone didn't charged and i am back at squre one. I even tried safe mode to try and get phone on, but it keeps getting back to the black screen and so there is progress again.
Please I do not want to lose my data, i want the phone to be as it was. please guys, this is a request and urge by me to help me solve this problem, i would really appreciate it.
Répondre à cette question J'ai le même problème
Indice 2
1 commentaire
I'm having the exact same problem. Charging it doesnt do anything. It goes tot he logo and then shuts down again.
par
Ajouter un commentaire
4 Réponses
Réponse la plus utile
It's a very common and stupid bug by Xiomi Mi.
It can be solved easily but u need to have more patience (mooorreee)
''Even if you connect the charger, you wont be able to see any sign of charging and continues blink (kind of boot loop). I am sure this should be the problem for you (not only you, more than a millions)''
1. Connect the phone with a charger, you may or may not see any sign of charging
2. Wait for at least 15 minutes and max of 45 minutes until you notice some sign of charging
3. Never disconnect the charger even for a single second while doing it
4. After a good amount time you get any of the below,
5. Phone booted without any issue :-)
6. If not use Power + Vol Up button to boot into recovery mode wipe all,
7. I not Vol + Down to fast boot. Keep charging until u see any sign of charging.
8. Try with another charger if it didn't
Let me know whatever result u get, I will give u the good solution, but don't forget to reply.
Cheers,
NallasivanG
https://twitter.com/NallasivanG
Update (02/22/2019)
Cheers,
NallasivanG
Indice 1
2 commentaires:
bro,i have the same issue and i charged my mobile for whole night but it's not powered on yet.what should i do??
par
i try to do all of those instructions above,but it doesn't work .. What should i do?
par
Have you try use another charging cable or another charger with 2 A output.
My wife phone xiaomi redmi note 4x mediatek have the same issue. Then try another charger with the same output, its work, the phone charged well.
Indice 0
1 commentaire:
Hi Divya, weather your issue got resolved if yes how pls update in detail Itoo have a same issue
par
It must have been quite a while since you bought the phone, that's why such a problem arose, now in order to retrieve your data you can only try having an expert change its software and reboot it.
Then extract all the data from it coz there's no guarantee how long your phone will last now.
I recommend you to buy a new phone now.
Indice 0
I faced different problem. Phone got drenched. Though I dried it but it won't charge. I shut it down. Surprisingly it started charging on connecting to adopter. It can be restarted while charging or after fully charged.
Now I have a different problem it doesn't charge unless restarted or shut down. I don't know how to fix it.
Indice 0
Ajouter une réponse
Dhaivya Buch sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 33
Total : 7,409
