Aller au contenu principal
Sorti le 25 septembre 2015. Modèle A1687/A1634. La réparation de ce modèle est similaire à celle des versions précédentes et nécessite tournevis et outils pour faire levier. Disponible en GSM et CDMA / 16, 64 ou 128 Go / Argent, Or, Gris sidéral ou Or rosé.
1041 questions Voir tout
Battery swapped but home button and touchID not working
Got that $29 battery kit, was excited to do the swap. Followed instructions step by step. Got it to power up and then... the home/touchID button doesn't work. I was careful not touch the home button or the surrounding area. Took it apart again and made sure all of the ribbons have connected correctly yet, nada :/. Someone explain to me what could be wrong? Thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
Only explanation I can think of is the home button extension cable coming from the screen is either damaged or the connector on the logic board for the home button is damaged.
Indice 1
1 commentaire:
i resorted to activating assistive touch... well at least I have a brand new battery :/
par
I would look for a tear in any of the cables. Specifically the Home Button to Logic Board cable that is with the LCD/Digitizer connector, and the front facing camera connector.
I also surely hope you've tried the good and faithful hard reset.
Indice 1
Ajouter une réponse
Binh Tran sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 58
