Ellen Myrup, give this a try and see if it helps.
for more instructions
Disconnect the power cable
Hold down power button
Reconnect the power cable
With the power button still down, press twice the “Cancel/Stop” red button
Release the power button
The printer is now in factory mode…(wait about 30 seconds until it says “idle”)
Press the down arrow (next to the “OK” button) until it says “Shipping Mode 1”
Press the “OK” Button
Now with it displaying “Without Cleaning” press the power button
A test page should print
Now open cover
Disconnect the power again
Take both cartridges out like normal
Close cover
Reconnect power cable
Press power button
Replace cartridges
The other way to reset it would be by using MPtools and the instructions are here MPtools should have come with your printer. Good Luck and let us know if it worked.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
1 commentaire
mine is same fault on mg4250 pixmar, tried the above for mp160 can't even get idle displayed. any advice please
par geoff.archer
