iMac Logic Board - Something's blown - can I fix it?
Hello all,
This is the Logic Board of my iMac. 820-3302-A
I'd like to know what has blown here if anyone can help. Capacitor ? Fuse ? Part/Item number ?
And most importantly, can it be fixed, or do I need a new/replacement Logic Board.
All help is appreciated.
Thank you
2012 iMac EMC 2544, 3.1GHz Intel Core i7-3770-s, Fusion Drive with 128GB SSD.
9 commentaires
@oldturkey03 Thanks for your reply.
You'll have to excuse my ignorance but . . .
'Package Size'
If I know the size can I get a new one ?
Can I solder it myself - I have limited skill at this.
It blew because someone ( not me ) probably put a screwdriver across the terminals.
Is it likely to have done more damage that I can't see ? Even buggered up the CPU or RAM or SSD ?
What's the best course of action here ? I could end up buying a replacement Logic Board and it still might not work !
All advice is greatly appreciated.
par Sponge Bob
@sponge_bob package size is the physical size of the component. From one end to the other. Yes, once you know what size you need you can get those from places like mouser.com or digikey.com as well as many others. Soldering a part on a logic board is always tricky and you need to remember that these parts are very smal. Sometimes you'll even require a microscope to properly see. I would consider sending it to somebody who does that professionally. Not sure where you are located so I cannot help you with that. Since this was a "accidental" shortening of the circuit, I think you'll be okay just replacing the part.
par oldturkey03
I have this exact same issue. Need a little guidance on what the piece is an what to get. The old part has actually fallen off completely. If I take it to a shop, how much should I expect them to charge to replace the ferrite bead?
par Brian Winnie
Did you ever find out what to order. I have the same issue?
par Zachary Lebwohl
I ended up taking mine to a local cellphone repair place and they are repairing it for $85.
par Brian Winnie
Voir 4 commentaires en plus
