Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La manette sans fil Xbox One modèle 1697 est sortie en 2015 et a remplacé la manette modèle 1537 et a corrigé certains des problèmes trouvés sur ces modèles. La manette modèle 1697 comprend une prise casque intégrée de 3,5 mm, qui la rend compatible avec la plupart des casques tiers sans avoir besoin d'un adaptateur. Cette manette a été abandonnée et remplacée par le modèle 1708.
Does anyone make a MicroUSB cable that works well with this controller
I've had this controller for 15 months and for the time I have owned it, I've never used the wireless because the Model 1697 controller only supports IR and USB connectivity. Because I don't own the wireless receiver and these controllers get terrible alkaline battery life, I've always used mine over MicroUSB to avoid having to buy batteries on a regular basis.
While this method works, I've been having a hard time finding a good MicroUSB cable that works well with this controller and doesn't wear out quickly.
The problem with these controllers is the connection is smaller then other MicroUSB connections. I have posted a picture of the connector in the controller for reference: (The Model 1697 controller is a minor refresh from the 1537, and the connector is the same)
Are there any good cable options I should look for that work well with this controller, or is it more or less impossible to find a good one that's 3rd party? The official cable from the Play and Charge kit doesn't work without the battery and doesn't work as a wired cable on the PC. It blocks 5V with the battery or 3.3V without the battery. The PCB in the cable is designed so it only works on the Xbox One console with the battery installed.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Solution retenue
How about soldering in a braided wire? https://www.amazon.com/dp/B012A1221Q/ref... just chop the micro USB connector off the end of this one.
Update (02/01/2018)
Actually, Here's a braided one for xbox 1 controllers. why braided? from my experience it extends the life of my apple cables soooo... https://www.walmart.com/ip/Microsoft-Xbo...
Indice 1
2 commentaires:
@nick not sure or not if you get a notification for updates, so here's this.
par
I'm not sure if Microsoft does the same thing they do with the Elite cable as they do with the Play and Charge cable. I doubt it, but I've never seen anyone with one yet to verify that.
par
The ones on monoprice.com are really good and come with a lifetime warranty.
Indice 1
Ajouter une réponse
Nick sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 28
Total : 3,045
