Messed up while repairing my phone, is there any hope of a fix?
I was replacing my honor 8 battery using this guide here: Remplacement de la batterie du Huawei Honor 8
Step 9 is where I messed up. Instead of just removing the cable from the connector, I removed the entire connector thingy along with the cord of the motherboard. I believe this may be referred to as removing the solder pads? Is there ANY way to repair this? I've heard that silver eproxy might work?
Carl Cooper add some images of your damage with your question. that way we can see what you see. Epoxy will most likely not work for this. Ajout d'images à une question existante
par oldturkey03
