Aller au contenu principal
Modèles A1297 Unibody : Début 2009, Mi-2009, Mi-2010 & Fin 2011
544 questions Voir tout
Why my screen showing black in green
I have changed out my broken screen with a new screen but after that my screen is showing green color in place of black color.
any help please
Update (02/04/2018)
I replace the whole assembly screen and it gives me a green color on black thanks from the external display the image is look ok there
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire:
What does an external display look like? Is the image OK there?
What did you replace the complete assembly or just the LCD alone?
Try using Google Translate to help you with your English.
par
Ajouter un commentaire
2 Réponses
Depending on your exact model you might find replacing the complete display assembly easier and much less work! Here's the IFIXIT guide: Remplacement de l'écran complet du MacBook Pro 17" Unibody within it you'll find the different screens this model had ($280 to $500 US). Replacing the LCD is also possible but its a lot more work! Here's the guide for doing this: Remplacement de l'écran LCD du MacBook Pro 17" Unibody the steps to Step16 are the same then from Step17 on to Step34 is taking the lid apart. The LCD panel cost is much lower ($150 US). But, the risks of breaking the cover glass as well as damaging the bezel & gasket have to be factored in.
Image MacBook Pro 17" Unibody Écran complet
Tutoriel
Difficulté :
Modérée
30 minutes - 1 hour
Image MacBook Pro 17" Unibody Écran LCD
Tutoriel
Difficulté :
Difficile
2 - 3 hours
Indice 0
Hi, it could be the cable that connects to the logic board and the LCD screen, but if the full assembly already included this cable then:" have you try to reset the PRAM and SMC"?. You can see the desktop ok in an external monitor so it is not the graphics card(controller), i have not notice that apple MacBook pro's have an inverter like PC's. in a PC if the inverter is bad then you will have those problems even with a new LCD screen.
Also there could be a small chance that even if the replacement is "new" that might be defective.
Indice 0
Ajouter une réponse
safoukou sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 664
