My Logitech Wireless M325 isn’t working.
Hi my Logitech Wireless mouse isn’t working. I’ve replaced the battery and doesn’t work. It’s a new battery cause I’ve tried with a couple different battery’s. The green light doesn’t turn on when I turn it on.
Model number: M325
11 commentaires
Hi @paperboypaddy ,
Have you checked that the switch is working? (use an Ohmmeter to verify)
Have you checked that the battery connection terminals are exerting enough pressure on the battery when it is in to ensure a good connection.
Have you checked that the battery connection terminals are still connected to the pcb and haven't come loose or broken off? Again use an Ohmmeter if you have to.
Also it is "batteries" ;-)
par jayeff
The thing is I’m not sure how to get it opened. So I can’t check the switch. I’ve checked the battery connectors and they’re fine.
par Padraic Hoselton
Download the Unifying software and try re-syncing. http://support.logitech.com/en_us/softwa...
Does the laser light up?
par George A.
@pccheese its a invisible laser mouse. So no the laser isn’t lighting up. ;-)
@paperboypaddy Logitech darkfield mice don't have an invisible laser. There is still a red light you can see. Look
par George A.
Voir 6 commentaires en plus
