Aller au contenu principal
Annoncé en mars 2015, puis commercialisé le 10 avril 2015, le Galaxy S6 est le prochain flagship de la série Galaxy. La version avec un écran incurvé est connue en tant que Galaxy S6 Edge.
Questions au sujet de 479 Voir tout
Galaxy S6 Active IMEI error
Hello, I have a Galaxy S6 Active and its IMEI is showing up as 350000000000006. Does anyone know how to fix this and get its original IMEi number back?
Répondre à cette question J'ai le même problème
Indice 5
Ajouter un commentaire
4 Réponses
Réponse la plus utile
@cabutcher99 so possibilities:
First----
Did you root and flash a 3rd party ROM?
IMEI corruption is known to happen a lot with these Galaxy S6.
If you did, flash back to stock ROM and it will resolve it.
Second----
EFS partition corruption
Try to flash the stock rom again.
If this doesn't resolve it, then you have hardware failure.
Third----
Run your real IMEI (sticker on the back of the phone) through swappa.com or imei.info to check the number.
If your phone was accidentally blacklisted, than you really do need someone to re-program to a different IMEI.
Obviously, make sure you backup your phone's data before doing anything. Use Samsung SmartSwitch to backup all your texts, etc. You can re-download all apps via Google Play Store later.
Indice 6
IMEI is corrupt (EFS partition), need to find someone that reprograms the IMEI back onto the device.
I've searched around and haven't found anyone able to fix 350000000000006 through firmware flashing, that's generic IMEI that appears only when the EFS partition becomes corrupt.
If you can find someone that does IMEI Repairs / has Z3X box they can fix up the EFS partition and put the IMEI back on.
Indice 4
My samsung galaxy 6 edge is showing SIM NETWORK UNLOCK CODE. How do i get it unlocked. My IMEI 350000000000006
Indice 2
Créer moi un compte IMEI
Indice 1
Commentaires:
Hi I have samsung Galaxy s6 edge and am facing network unlock code problem please I need help
par
Ajouter une réponse
CAB sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 15
Total : 4,756
