Spinning down External HD when not in use?
I have an external drive with 2 partitions; one for SuperDuper, and one for time machine. I have used AppleScript to automatically mount this External when SuperDuper is scheduled to clone; then automatically dismount the HD when SuperDuper completes the clone. This automation comes in handy being that I don't have to interact with the software at all for daily backups. Now, the problem is that the HD is constantly plugged via my powered USB Hub all day-everyday, so the HD is constantly spinning. Is there any software available that I can use to spin down the drive when it's idle for a while then spin up when SuperDuper mounts it?? Google has yielded no results. ;o/
5 commentaires
What operating system are you using? What model is your external HD? Also it seems to me if your external HD doesn't have an external power source you may be able to write a script or find a program to shut down the usb port when not needed. The same end result would be accomplished.
par ABCellars
Good Idea!! Im running Snow 10.6.6. I have a HitachiHD that came with my Mac in a generic enclosure. It's a USB enclosure and I do have it connected to a powered USB hub being that I noticed significant transfer speed increase this way compared to the Mac's native USB ports.
par Majesty
It's asleep. AS long as I kepp the internal HD busy it won't snooze, so this is as good as it gets.
par Majesty
There are lots of little scripts to do that once every five minutes, need one?
par mayer
Sure; fire away.
par Majesty
