Why are my reverse lights staying on even when not in reverse
For some reason my reverse lol ight are staying on regardless if I'm not in reverse
Manuel Saturria on a manual transmission it is the back-up light switch that may have failed. On an automatic the backlight gets turned on by the gear position switch. So you do need to check the switches first. If they are closed it does not matter if you are in reverse since the switch no longer open the circuits. The lights will always be on. You do want to let us know what type of transmission your Honda has and the exact year of it as well.
Manuel Saturria the switch is on the transmission housing.
I have a manual transmission and it's a 2000 Honda Civic ex coupe 1.6l
Usually warning you of a service,,
Try new fluid top up. Xx
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 54
Total : 12,416
3 commentaires
Manuel Saturria automatic or standard transmission?
par oldturkey03
I have a 1998 Honda Civic automatic transmission. The reverse light comes on when I turn the lights on and stays on
par Josephpokini
Car has transmission problems, waning lights for service..
par whamwacka
