ZStech,
Beyond a parts problem, one common age-related issue on any iPhone is failure of the motherboard's USB logic integrated circuit codenamed "TriStar" on the iPhone 6 generation.
Imagine your charging system as a group of people trying to walk into a building. The building is the battery. The charger port is the gate to the building. The flow of people is the flow of electricity into the device from any outside power supply. The TriStar IC is the gatekeeper. When the gatekeeper dies, no one can get in.
While TriStar can die due to to age or water damage, another common killer is knockoff Apple lightning cables. Every time fake cables are used to charge a phone, there is risk of damaging TriStar. The fake cables are designed to tell the gatekeeper they are trustworthy, yet they contain no charge potection circuit. Imagine some guy who doesn't belong trys to sneak past the gatekeeper, then punches him in the face while he's not looking. TriStar can only be punched in the face so many times...
If you are experiencing a wave of unexplained dead devices in your shop, especially devices that came in working, but will now not power on with new batteries, you may have a bad supply of chargers. If two shops are buying and testing used phones, the first shop using OEM cables, the second using fake cables, than the second shop will eventually have a higher rate of unexplained DOA's.
I hope my dumb metaphors help.
A voté
Annuler
Indice
0
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
