Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repair manuals and information for the Microsoft Surface line of tablets.
My charger doesn't charge.
After going down from lack of battery, my tablet won't charge. The charger Light doesn't turn on, and I need some solution that doesn't involve buying a new one or throwing everything against the wall...
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
1 commentaire
Just tested with a multimeter, and apparently the charger is working...
The problem must be in the battery.
par
Ajouter un commentaire
1 Réponse
Solution retenue
@gc05 you could check your charger with a multimeter first to make sure that it is working. If it is then you are possibly having issues with either the charging port Microsoft Surface Charging Port Replacement or the battery. If your battery is depleted or discharged below the charging threshold it will no longer accept a charge. Replace the battery and see if that works. Microsoft Surface Battery Pack Replacement
Image Microsoft Surface RT Battery Pack
Tutoriel
Difficulté :
Modérée
5 - 10 minutes
Image Microsoft Surface RT Charging Port
Tutoriel
Difficulté :
Modérée
15 - 30 minutes
Indice 2
Ajouter une réponse
Gil Cancela sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 9
Total : 25,415
