Aller au contenu principal
Model: HX9300 Series The Philps Sonicare DiamondClean Series can be identified by its model family number: HX9300. All HX93xx models are the same toothbrush. The third and fourth number determines the contents of the box. The numbers after the slash (/) determine the color of the handle.
Questions au sujet de 11 Voir tout
HX9360 can't turn on
I measure the battery about 3.8V.(F1 /R6 point).So I think the battery is fine.
But I push the button can't turn on it.But put into the cup can charge the battery.
So how do I to check the board or more action?
thanks
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
I have probably a similar issue. Who can find and change a battery here?
par
Ajouter un commentaire
2 Réponses
Réponse la plus utile
swat1230 your voltage maybe fine but it is not a good indication of your battery being okay. It is possible that your battery simply does not hold enough charge to supply the demand. I'd start with a new battery first, then re-evaluate. Check your switch circuitry etc. with your multimeter.
Indice 3
I'm having the same problem. Have you fixed it?
Thanks!
Indice 1
2 commentaires:
I have also checked the switch circuitry, which is fine. Additionally I have also connected an external power supply with 3.8V. Unfortunately it didn't helped.
par
I have exactly the same issues, battery power is still good. Have so. fixed the problem yet?
par
Ajouter une réponse
swat1230 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 27
Total : 1,786
