Aller au contenu principal
Cuisinart Griddler GR-4N a five-in-one kitchen appliance to be used as a contact grill, panini press, full grill, full griddle or half griddle .
Questions au sujet de 16 Voir tout
How do I replace the coil and the wires leading to the coil?
Hello, one my upper heating coil, one of the wires leading from the power to the coil has rusted and fallen away from the coil, so it doesn't heat. Is there a replacement wire assembly for this, and how do I open the griddler to detach and then reattach the new wiring to the griddler so that it will heat up again?
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire:
Hi Karen,
do you have the solution for that?
I have the same problem.
par
Ajouter un commentaire
1 Réponse
Karen - all the wires are steel WELDED in place,,, thats the rusting problem.
To repair, remove all rust from the burned post. A small raspy file is used. Skin the insulation back to rust free wire and wind 1-full-coil around the post. Now comes the difficult part.
It must be silver-soldered, or brazed, which requires a flame. I cannot explain the how-tos in this small box.
Do not attempt tape, sooper-glues, or try-this-stuff. These GeorgeFormanFryers can knock you down !
Indice 0
Ajouter une réponse
Karen Wolfe sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 117
