Aller au contenu principal
Sorti le 25 septembre 2015. Modèle A1688/A1633. La réparation de ce modèle est similaire à celle des versions précédentes et nécessite tournevis et outils pour faire levier. Disponible en GSM et CDMA / 16, 64 ou 128 Go / Argent, Or, Gris sidéral ou Or rosé.
Questions au sujet de 2554 Voir tout
iPhone 6s home button flex cable issue
Hi guys and girls,
I'm running into an issue with iPhone 6s screen which I accidentally broke its home button flex while i was repairing (refurbish) the screen, the screen is working fine and 3D touch is working but home button is not and have test my home button on other screens and it's working so the issue is actually with the home button cable on the screen , I know it's can be replaced with changing the backlight, I only want to replace the first layer from the backlight, the problem is I need to order one and wait for at least 3 weeks, I'm going to tear it down and try to take one from other screen, has anyone done it?
Thanks in advance
Répondre à cette question J'ai le même problème
Indice 1
Commentaires:
what do you mean the home button can be replaced by changing the backlight
par
you mean the cable inside the screen or homebutton small flex?
par
Thanks Ben that's what cable I meant, I never changed screens backlight as I just started refurbishing but anyways thanks for you reply
par
Ajouter un commentaire
1 solution
Réponse la plus utile
He is talking about the home button extension cable that goes with the backlight layer of the screen.
Taking one from a known bad screen isn't a bad idea, it should be the same process as refurbishing a screen.
Cette réponse a-t-elle été utile ?
Indice 1
Ajouter une réponse
Jaffar Almousa sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 131
