Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Repair guides and support for a wide range of Vespa scooters.
2015 Vespa Primavera 150
My wife rides a 2015 Vespa Primavera 150. Over the winter the battery went dead and will not hold a charge. Is there a battery upgrade from the standard acid battery? Like lithium ion or any other that you can think of?
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Réponse la plus utile
@americancj7 no because the charging circuitry would have to be different. In your case for now I'd replace the battery with a new one. It is most likely shorted out and thus does not hold a charge. If you are really handy you could most certainly build one out of capacitors but this will depend on your abilities and potentials to getting the right parts.
Indice 1
If replacing the battery dosen’t solve your problem then you could have a problem with the voltage regulator if your battery dosen’t hold charge. Try to see if that is not faulty and replace it.
Indice 0
Ajouter une réponse
Tyler sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 63
Total : 1,046
