Aller au contenu principal
Sony's 9.2 megapixel HDR-CX675 released in December 2015.The handycam captures 1080p HD recorder.
Questions au sujet de 12 Voir tout
Horizonal lines on LCD and Tape header noise TRV118
Having an issue with a Sony Handycam Digital 8 that I picked up from a thirft store the other day.
Model: CCD-TRV118
The problem is intermittant....
- The LCD screen will show horizonal lines, usually when I touch or tap the area where the tape is located. This can happen when the tape door is closed, but the problem presents itself better when I try to tap it when the tape door is open.
- Sometimes the LCD screen will stop showing the lines, but sometimes, I have to turn the whole unit off and on again.
- When the LCD sceeen is showing these lines, you can hear the tape deck whirring, like the headers are trying.
I was thinking the camera 'thinks' it has a tape, when it does... maybe something is loose or dirty... However, why would the LCS sceen show pure horizinal multi-colored lines at the exact same time?
Any help would be appreciated!
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
IRRC there are 2 ribbon cables that run between the main camera body and the display. One of these cables either has a crack or is loose in its connector inside the camera body. This should be fixable by re-seating the cable or replacing it.
Dan
Indice 0
Ajouter une réponse
sean gee sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 136
