La ligne d'ordinateurs portables MacBook Pro a été conçue pour les utilisateurs professionnels. La gamme MacBook Pro inclut le MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17", et le MacBook Pro 17" Unibody .
Questions au sujet de 14954 Voir tout
Power on - no display but HDD is running
Hello,
When my MBK 2007 is turned on, there's no display on the screen but I noticed there's some sounds on the HDD. It persisted for few days and finally worked as usual today. After I turned it off, and turned it back on after few hours, the same problem occurs.
The thing is, when it was working normal for the few hours, the display looks perfect, and everything else seems normal. So I'm not sure if the problem could be due to other parts except for HDD and display?
Appreciate the help.
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
Sounds heat related. To try to isolate the problem, hook it up to an external monitor and see if the picture goes out on both. Hold a flashlight at an angle to the screen and see if you can see the desktop. See if moving the LCD makes any changes.
Cette réponse est utile ?
Score 2
Commentaires:
I don't think, it's heat related cause the PO mentioned it happens on cold boot. Maybe a cabling or graphics card issue?
par
Thanks, Maj. - I've reread your question several times and am still not sure if this is happening on a cold boot. Would you confirm. A cold boot would be after it's been shut down for a couple of hours.
par
Hi Both, thanks for the input and yes, it was cold boot.
par
Did you get any answers from the other tests?
par
Well i'm trying to get the tools so i can pry open my machine to check on the cabling...i hope it's only cabling problem so i dont need to get a new machine..
par
Voir 2 commentaires en plus
Ajoutez une réponse
Gerard sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 894
