Aller au contenu principal
A 5.5-inch smartphone by Oppo, released in August 2016. Includes a non-removable 3075 mAh battery and a 16-megapixel selfie camera. Model A1601.
41 questions Voir tout
How can I make my phone ring longer for incoming calls.
INCOMING CALLS RINGING TIME
How can I increase the number of times my mobile phone rings
for an incoming call. Only rings 3 times and I am an elderly lady and
cannot get there in time.
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
1 commentaire
I am from South Africa and on the Vodacom Network. I went to their web page but the is no such place on the page with an answer...
par
Ajouter un commentaire
3 Réponses
Solution retenue
Hi @bettejoy ,
Go to your mobile phone service provider’s website and look for how to change the ring time.
Alternatively just search online for how to change the ring time (insert service provider’s name)
Each service provider has a different code number (or other options such as you can alter it in your phone account manager page or contact them directly etc), that you can enter from your phone to extend the ring time. Usually it is in 5 second increments up to 30 seconds, but it may vary between providers.
Indice 4
4 commentaires:
Thank you for your help, I will follow this through.
par
To: Jayeff: Thanks so much, all fixed and will ring for 30scds.
Betty Thompson.
par
Hi @bettejoy ,
You're welcome.
Glad that you got it fixed OK.
Cheers
par
Thanks for posting this, as I too was frustrated with the short ring time. Hopefully mine is fixed after doing this sequence.
par
Hi @Francois Nel
You should first check the status of call forwarding by dialing *#61# from your phone
the status will give you the voicemail number that you are being forwarded too. Use this number to setup the revised forward with longer wait time
So for vodacom the voicemail number should be 278214
Use the following format to increase the ring time
*61*[voice mail number]*11*[wait time in seconds - 5 second increments e.g. 15, 20, 25, 30 (30 is maximum)]#
Dial *61*278214[insert your phone number]*11*25# to forward your calls after 25 seconds to your voicemail. If you want it to ring for 30 seconds, type 30 instead of 25
Indice 1
2 commentaires:
The message I recieve back just says the MMI code doesn't work.
par
@Francois Nel
Contact your service provider and ask them how to extend the time
par
Using the keypad on your mobile phone, dial the following sequence: **61*121**11* (number of seconds: 15,20,25 or 30). Example: To extend the ring time to 30 seconds, dial: **61*121**11*30. 3.
Regards,
Will
Indice 0
Ajouter une réponse
Betty Thompson sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 43
30 derniers jours : 224
Total : 6,178
