My battery drain too quickly even after battery remplacement
Hi I'm new here,
So it's been 2 days that I've change my battery and I've notice an drastic battery drain (1% every 5 mins equal to 8 hours/day) even if the phone is in standby mode and sometimes my lightning cable is not recognized by the phone (this accesory may not be charge the phone) and does not charge (it's charging if I connect it to the computer).
My phone is recognised by itunes and I'm still able to restore.
I think the tristar U2 IC chip is broken but I'm not so sure
Thanks for your answer
PS:Sorry for my bad English I'm a French speaking/writing guy :)
4 commentaires
UPDATE:
So I've change my battery as recommend but it's still the same issue :( .I can restore my iphone without getting error, the phone is hot and have HUGE battery drain...
PS: the phone takes a lot of time to charge (3h30 to a full charge)
and when the battery's dead it does not take charge or get stuck in a bootloop :/
par Greg
Hello again! After trying everything you are still having the issue? Then it may honestly be the U2 IC chip. Sorry my recommendations did not work, and that it may be the worse one if the issues, but if you know how to solder, you can fix it yourself for fairly cheap, but if not, it will be fairly expensive and I would recommend just upgrading your phone from there because the price for a new or newer phone over fixing your current phone is honestly equal.
Best of luck!
par SectorGaming
If the phone getting pretty hot there is clearly a short circuit in the phone. Have you tried booting phone without front and back camera installed and see if it heats up a lot still?
par Ben
Thanks everyone for your help but even if I have some solder skills I'll just buy a new phone
par Greg
