Le Huawei P8 Lite annoncé en avril 2015 unit beauté et simplicité. Ses caméras professionnelles vous permettent de prendre des photos naturelles et nettes même dans l'environnement le plus sombre. Le mode beauté met en valeur les atouts de son propriétaire sur chaque selfie.
Questions au sujet de 93 Voir tout
Dropped my phone in sea. help! CAN FIX IT AFTER 15 hours?
Hey guys yesterday my phone dropped in a gulf at midnight...if I swim at the morning and I can take it. It is 1.40 m from the ground
Update (07/12/2018)
I disassembled all in the phone expect the lcd and ear vibrator. . I have to roll it off completely or I can drop it with the pieces in the liquid you told me about.
And correct I am from Greece..also The battery is for rubbish now
Répondez à cette question J'ai le même problème
Ajouter un commentaire
1 réponse
Réponse la plus utile
If you're in Greece as your name hints to, it's just a pleasant swim right now, pretty hot here in the Med ;)
Nobody knows what happens to a submerged phone, but if you fish it out don't try to turn it on and don't put it into rice. Remove the logic board following the guide, put it into Isopropyl alcohol and let it soak there for an hour, then remove it and brush it with a soft toothbrush and let it dry for a day. Meantime buy a new battery and then try your luck, reassemble everything and hope for the best.
Remplacement de la carte mère du Huawei P8 Lite
Cette réponse est utile ?
Score 3
Ajoutez une réponse
Thanasis Katsoydas sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 27
