Locating display fuse XZ Premium (picture)
Hello all,
My dad's XZ Premium 'stopped working' like two months ago, he took it to a random repair shop who opened it and poked a lot of components so there's no warranty anymore they thought it was a bad battery for some reason.
I found the phone still worked but the screen appeared to be broken so I thought i'd fix it for fathers day with a replacement screen.
I installed the replacement screen but it still wouldn't work, then I found that if I boot it or make a screenshot even though I don't see anything the screen does in fact show an EXTREMELY low change in brightness. It's barely visible at all.
So I supposed it wasthe backlight that doesn't work, so I've read about backlight fuse/jumper repairs on the motherboard. I check the backlight fuse with a multimeter, and it appears to work fine. Then I want to proceed to check the display fuse, but I can't seem to find it given it is marked with the L like it was on the xperia z5 i've seen in video tutorials.
The XZ Premium motherboard around display connector:
(you can see the V marked backlight fuse just on the left side of the display connector(long white)
The Z5:
Hopefully I can find it and find that the fuse needs fixing otherwise I won't have a clue what the issue is anymore... ;/ If someone has other suggestions, that would also be highly appreciated.
Thanks in advance.
Edit:
Thanks to Smartfonefix I think I found the issue, visually they already look in bad shape not exactly sure what to test on with these I tried a bit with the diode mode but the numbers don’t say much to me (I do have a working XZ Premium myself to compare values to but I don’t really want to void the warranty on that) though I don’t get a beep on the coil and diode. I’ll try to find out how to confirm it’s either one of these or both but even if it is one I doubt it’s a diy fix. (i think it’s the correct ones that are in the top left/middle-left.
6 commentaires
Having same problem with a z5 I tested new screen before fitting. And Once new screen was fitted! I have No Lcd or back light. Second screen was the same. What causes this problem? Battery still conected? A friend had same problem after screen replacement.
par lee moran
You can check out this video for the z5
https://youtu.be/lvhnkQUxuV0
par Mark M
Hi Mark. I have the exact problem. But I'm in South Africa. Do you know anyone who could help me? I have no idea where I'm going to find parts. Are both these parts reristors?
par Braam Steyn
What is the name of the defective part?
par furkan Akbayır
Hi, there is a capacitor who got short and then coil got burned and diode as well - all this parts you can get from iPhone 6s mainboard - I fixed this today - worked 100% - just put diode in correct direction - all parts ( these 3 diode, coil, capacitor ) have to be replaced. Good luck.
par Lukasz Lazarowicz
Afficher 1 commentaire en plus
