I dropped my Kindle Fire in water
I dropped my Kindle Fire in water. It was for only a moment. I grabbed and wiped it down. Now, what should I do?
Hi @candycatie
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the tablet’s operating design and could damage the components. The corrosion process starts immediately and continues until it has been cleaned properly
First do not turn on your tablet and then you need to remove the battery as soon as possible from the tablet to minimize further damage.''
Then you need to dis-assemble the rest of the tablet and clean all the affected parts using Isopropyl Alcohol 90%+ (available at most pharmacies),to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70%, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that in general, describes the process.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the tablet might continue to work correctly.
Here is a link to the ifixit Kindle Fire guide which may be of some help.
If this process seems too daunting, take your tablet to a reputable, professional mobile phone repair service experienced in water damage repair and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
Try using the rice in bag method and see if that helps?
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 602
