Aller au contenu principal
Dell 19" LCD Monitor, Charcoal-Gray in color, released in 2004.
Questions au sujet de 7 Voir tout
Have a white screen on power up
Moniter was on and all of a sudden went white. Now it is always white no matter what I do. Is it a motherboard issue or something else?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Réponse la plus utile
White screens are usually indicative of a bad hard drive or corrupted boot system.
Indice 2
mrbruce300  on your monitor this just means that only your backlight is on. You will have to check the video source and see if it is connected etc. If the monitor does not show a menu etc. on startup when disconnected from a video source you most likely have a bad main board.
These monitor had issues with bad caps, so you will have to take a look at the boards and check for an obvious damage. Post some images of the boards with your question so that we can see what you see. Ajout d'images à une question existante
Here are the disassembly instructions disassembly.pdf
Indice 2
Ajouter une réponse
mrbruce300 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 62
