Grinding noise on startup of spin cycle
Making loud grinding noise at first part of spin cycle and had a spot underneath it on floor that I'm pretty sure was grease or oil.
A washing machine making a loud noise when spinning means a part has become worn out or loose. The issue that is causing the loud noise could be a number of different parts inside your washer. If the loud noise only happens when the washer is in spin mode, this can be a sign that the main tub bearing is worn out.
If you would please listen to it and give us more information about when it starts and the duration.
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 52
Total : 2,971
