Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
6.1 megapixels, ISO 200-1600, DX format, 1.5x field of view crop
Questions au sujet de 43 Voir tout
Flash is not in sink with picture
When I take a picture the flash goes off, how ever the image looks like no flash was used, I went to menu reset but this did not work any suggestions? is this a setting issue or do I need to take the camera to a repair shop.
Répondre à cette question J'ai le même problème
Indice 0
Commentaires:
How far away from the subject were you.. There is a fairly limited range on these. Are all images dark? Including ones taken in natural light?
par
Ajouter un commentaire
2 solutions
Réponse la plus utile
After reading through the manual page 94-104 I think it might be a problem with the automatic settings. I would most certainly try to adjust the settings before taking it in for service. When your pictures are underexposed, Nikon recommendations are
If sensitivity (ISO equivalency)is under 1600, raise sensitivity.
• Use built-in Speedlight.
• In mode:
S Lower shutter speed
A Choose a larger aperture (smaller f/-number)
Just in case you've lost your manual, it is available here Of course once you have exhausted your option you may have to take it in for service of the flash. I suppose you could try a horseshoe flash as well. Good Luck and let us know if your pictures get illuminated.
Cette réponse a-t-elle été utile ?
Indice 2
This can happen if your flash is set to commander mode. Make sure that the flash is set to iTTL mode.
Indice 0
Ajouter une réponse
Margaret sera éternellement reconnaissant.
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 912
