Hi Bubba. I have a 94 Ranger myself and I had just replaced the stock radio. I had static also. Your antenna is on the passenger side, correct? Am I also correct to say that you bought the truck used? I’ve seen antenna wires running from the radio, under the dash and glove box, through the quarter size hole with the rubber boot (under glove box and through the right metal wall) so that when you open the passenger door, you’ll see the black wire between the door hinges and up to the antenna. If that’s the case, the antenna wire is either pinched or cut from the door closing on it. No continuity; no music, just static. As for the power, it sounds like you have the yellow wire (12v constant battery)connected. You would want to disconnect your negative post from your battery, go to the back of your radio and disconnect that yellow wire and use electrical tape to cover the end to prevent short circuit. Next find the red wire, it shouldn’t be connected to anything, that is your 12v ignition switched and connect to the red wire on your trucks radio wire harness. Then reattach negative battery post. If you have the radio playing when you turn your car off, radio is off too. Starting Car, radio is on. I’ll check back with you. CYA.
A voté
Annuler
Indice
0
