Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La Nintendo 3DS XL 2015, vendu en tant que New Nintendo 3DS XL, est sortie le 11 octobre 2014 au Japon et le 13 février 2015 en Amérique du Nord.
When I turn 3DS on, blue light appears but screen is black (has CFW)
So I was playing ACNL, then I put my 3DS in sleep mode after I was done playing. A week later, I come back to play and the screen is all black, though the blue light is still there. I figured it must have somehow froze, so I held the power button to turn it off entirely. Unfortunately, after that, every time I tried to turn the system on, the blue light appears, but the screens remain black, and I can’t actually do anything on the system. I‘m not sure what to do. If it matters at all, it does have CFW installed, but I doubt that’s the issue, as it’s been installed for about a couple years by now with no problems.
Répondu ! Afficher la réponse J'ai le même problème
Indice 18
7 commentaires
Anyone have any ideas on what could possibly be wrong if I have tried to Wi-Fi fix and it doesn't make screen turn on? I'm at a loss. This originally stopped working 13 months after purchase and Nintendo wouldn't fix because it was after 1 year warranty window. And I was angry so was boycotting paying the $150 fee to have fixed. Now I wish I would've done that because they do not even repair these any more
NINTENDO 3DS XL "galaxy"
par
Do I need a new battery? I did everything I could and updated it and got all the new files and deleted the old bad ones and everything. it’ll turn on for a little, but it always goes right back to it. It’s weird cuz you can see the screen turn slightly brighter like it’s on, but it’s not I don’t know. Any advice please anybody???
par
does anyone to fix it without opening the ds\
par
I have the same issue like some times it will work without a problem but the next day it's just a black screen, but the blue power light is still on, how fix please someone help. At this point, i want to` buy a new 3ds
par
@icebluelugia yet again, could be bricked, have you tried updating any software left or do safe mode? lmk
par
Voir 2 commentaires en plus
Ajouter un commentaire
11 Réponses
Solution retenue
Hi!
You could try the following:
  1. Remove the battery
  2. Press the power button a couple of times
  3. Plug in the power adapter. Try turning it on.
  4. Remove the power adapter
  5. Insert the battery, plug the adapter in
  6. Try to power the console on again. If it works, you’re good, otherwise I’d try the same again also with removing the SD card.
Indice 22
20 commentaires:
Sorry for the late reply. I actually had seen someone else suggest this as well so I wanted to try it, but unfortunately the screws are stripped so I can’t actually get to the little nudge in order to pull out the battery. But the back cover itself broke off since it was kind of cracked, so I’m able to access the SD Card, just not the battery. Is there any way I can remove the screw?
par
I just made an account to say thank you. I was going crazy and couldn't find how to fix it, thank you so much!!!
par
This worked! I was about to give up hope when the wifi-chip fix only worked once, but before my eyes it finally turned on. Thank you so much!
par
Pranav, if you still need a way to open up your 3ds (after 4 years) you can try using a rubber band between the screwdriver and the screw, and as a last result you can drill off the screw top.
par
Thank you! It worked!
par
Voir 15 commentaires en plus
This is a fairly well known bug with luma. Turn it on and leave it open and undisturbed for about 10 minutes. If it boots by then, you're good to go and probably won't have to worry about this again
Indice 5
39 commentaires:
Do you have any advice for a 3ds that is having this problem without any CFW installed?
par
@standardtoad When did it start, and what were you doing with it just before?
par
Well, this happened some time ago and I basically gave up. I was playing some MH4U and doing the online mode when the 3ds crashed. It was able to reboot, but after I continued playing it crashed again and got stuck on the black screen of death. I then used the safe boot to try and check for updates, but I wasn't missing any and the 3ds still wouldn't boot normally, always going to the BSoD. I then checked online and tried methods like disconnecting and reconnecting whatever the thing on step 12 of the teardown highlighted in orange is. That worked for about 2-3 boots until it crashed again and got stuck on BSoD after playing some online Pokemon. Around this point, the safe boot no longer worked, since it would crash after about 2 seconds. The last thing I did which worked temporarily was the procedure mentioned in the top answer here, but it only worked for one boot and didn't work after that. As of now, the 3ds no longer boots even using safe mode and none of the methods that worked before succeed any more.
par
The teardown I mean is the Nintendo 3DS XL 2015 Motherboard Replacement. I have the New Nintendo 3DS XL, SNES model. Nintendo has already rejected my device for repairs, which I guess was because either the warranty expired or because I bought it from Amazon instead of directly from them.
par
@darthmango I don't know if this is enough information to figure out what is wrong, but the main problem that seemed to happen was that even though the 3ds was updated and had internet connection, the crashes all seemed to happen when playing games and using the online features.
par
Voir 34 commentaires en plus
Download the latest version of Luma3DS and copy the boot.firm file in the archive to the root of your SD card, overwriting any boot.firm file that might already be there.
Indice 1
3 commentaires:
The link to the latest release of Luma3DS is always available on GitHub at https://github.com/LumaTeam/Luma3DS/rele...
par
Also try a different SD card. If none of this works, try holding (L) + (R) + (A) + (D-Pad Up) all at the same time, then while still holding them, turn it on. This should bring up a System Settings menu to update the system. As long as you put the latest boot.firm on your console beforehand, updating from this extra menu (called Safe Mode) should be safe to do. Updates using B9S+Luma are safe, as long as you update Luma too. (if you don't update Luma, you'll run into the same issue you're already having until you put the new boot.firm on the SD card.)
par
This worked for me when I updated Luma3DS.
After doing my research, my son updated the 3DS system. So I had this problem.
par
So I litteraly removed the sd card, turned it on and it worked then put the SD card back in after turning it off. Works fine again.
Indice 1
1 commentaire:
This worked for me too, just turned off my console removed and inserted the sd card and then it turned on
par
Okay so I had this EXACT problem with my 2ds (instead of a regular SD card, I had a 64gb micro SD inserted into a regular SD card adapter) turns out it was the adapter that wasn't working (not the micro sd) as once I replaced it with another adapter I had lying around it booted up per usual and I've had no problems since!
Indice 0
Hi I need help as well my 3ds is doing the same thing I updated it and got rid of the old files I replaced and did everything. I even took out the sd card and back and it would sometimes work for a little, but then would just start doing it again. It’s weird cuz the screen gets slightly brighter like it’s on when it’s not. I think I might need a new battery, but i don’t wanna buy one if that’s not the case yk.
Indice 0
The way I got it working was I removed SD card turned it on and got a crash dump thing turned it off and then popped it back in and I powered on and held select to bring up luma and after that it booted up with all my stuff intact
No wonder some guy said that luma will prevent your 3ds from becoming bricked
Indice 0
1 commentaire:
is it still able to boot with no SD inserted?
par
I'm having a black screen issue with my 3DS after the Luma config v13.1.2 screen. After I save and exit, the screen goes black again. Removing and replacing the battery temporarily fixes it, but the problem returns. Also, I can't access recovery mode despite trying the right button combination. Any advice?
Indice 0
when i do the r l up on d pad and a button it wont load into the safe mode screen please help me!
Indice 0
I have the answer
First you shut off your 3DS by pressing and holding the power button then you remove the SD card or microSD card, then you boot it on and it should boot up back normally. Then you can re-insert the microSD card while the 3DS is still on.
easy fix
Indice 0
How to fix Black screen blue light
Indice 0
Ajouter une réponse
Pranav Iyer sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 67
7 derniers jours : 434
30 derniers jours : 2,159
Total : 151,069
