Aller au contenu principal
Tutoriels de réparation et d'entretien pour différents types et marques de télévision.
9030 questions Voir tout
Sharp aquos LC-32CHG6021K TV
My Sharp aquos LC-32CHG6021K TV just updated and now everything is upside down how do I flip it back
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
10 commentaires
Hi @goodhart ,
Did you try the "reset" option found in the TVs "setup" menu? You didn't say.
Be aware if you reset the TV you'll have to scan for the channels again as they will be cleared from the TV.
par
Did mine 30 mins ago as well same thing happened any luck yet ?
par
yeah my tv has done the same thing after update,and iv been though every setting this morning and still wont go back to normal
par
Hi @cjas32,
You may have to contact Sharp about this.
3 different TVs exhibiting the same problem after performing an update is too coincidental to my mind
par
Sounds like something on their end within the update hence why multiple people have had the problem
par
Voir 5 commentaires en plus
Ajouter un commentaire
1 Réponse
Solution retenue
I have the same problem. The Aquos smart TV just updated and the image turned upside. I called the technical support unit of sharp in the UK. Problem solved. Solution: press menu button on the remote; urgently press 1147; select item 7(panel), press item 9(Mirrow). Done. Good luck!
Indice 5
1 commentaire:
This worked for me thank you so much
par
Ajouter une réponse
Ronald leino sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 3,206
