Aller au contenu principal
Intel Core i5 bicœur avec 3 Mo de mémoire cache L3 de 1,8 GHz
371 questions Voir tout
Screen only works well with external display.
Screen goes dim without a connection to an external monitor. Works fine with an external monitor. By itself it sometimes works but will flicker every once in a while. Or it will just remain very dim. F2 key is unresponsive during these fits. Screen returns once external display is plugged in.
I have a new logic board and new battery installed. The display problem existed before this repair.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Try to check the connection to the display may be they are rusty connectivity between the connection.
par
Ajouter un commentaire
1 Réponse
Solution retenue
Flickering is quite often related to LVDS cable issues. If logic board was replaced I guess it was for a reason..if that involved liquid damage or image issues it’s likely cable was damaged and needs replacement too.
Indice 2
Ajouter une réponse
Mark Waddington sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 67
