Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
3 commentaires:
Hi,
Did you notice my comment in the answer provided by @ajcooke01 about the possibility of having to remove the HDD in order to get the ODD out? To get to the power input socket to replace it if it is faulty, the systemboard will have to come out
Hi,
repairing pwer adapter on motherboard
Click on the "show 2 further comments" link in the answer to view it, if you didn't see it.
Have you checked that the power adapter is OK and has a voltage output of 19V DC?
par jayeff
@jayeff Thank you! I was going to suggest exactly what you said, just didn't get around to doing it.
par [deleted]
discovered I hadn't removed a screw at the rear of the dvd player, once I removed that out popped the dvd player
par Jack Carruthers
