Works only with Power Adaptor attached though Battery is 100% .
MacBook Pro late 2007 will operate only with the power adaptor attached. The MacBook charges the Battery and shows 100% Charged as confirmed by the green lights on the battery. Removal of the adaptor at any time shuts down the computer completely.
Is there a fix for this comdition?
Une réponse ! View the answer J'ai le même problème
Commentaires:
Apple MacBook Pro "Core 2 Duo" 2.2 15" (SR) Specs
Identifiers: Mid/Late 2007, 2.4/2.2GHz* - MA895LL - MacBookPro3,1 - A1226 - 2136
par
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
Vous avez déjà réparé quelque chose ? Vous êtes un génie.
Partagez votre réparation avec le hashtag #ImAGenius
Nous sommes tous des génies
1 réponse
Solution retenue
Well this is a puzzling question. Please download and run Coconut battery and give us the results. Here's the application: http://www.coconut-flavour.com/coconutba...
Cette réponse est utile ?
Score 2
Commentaires:
Coconut Battery reports Current charge: 4744 mAh
Maximum chare: 4927 mAh 96% as per battery monitor
Battery Capacity: Current Capacity 4927 mAh Design capacity: 5500mAh 89%
Details:
Mac model: MacBookPro 3.1
Age of your Mac 43 months
Battery Load cycles: 148
Battery temperature: 29.8 C
Battery Power Usage: 0.0 Watt
Is this what you (mayer) expected?
par
I'm not ignoring your response, I just don't have an answer. Would you give us the last three figures of your serial number so we know exactly which machine you have. My answer would be different if this was not the unibody model.
par
Last 3 numbers are X91.
par
I think your best bet would be to replace the battery connector. You seem to be getting power to it but not from it. Here's the part: MacBook Pro 15" (Models A1211/A1226) Battery Connector
par
Ajoutez une réponse
Earl Stokes sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 579
