Aller au contenu principal
The De'Longhi EC155 is a Pump Espresso and Cappuccino maker.
23 questions Voir tout
Why is it making weird sounds after it ran out of water? And no crema?
It ran out of water while making some coffee, and now it makes a very small amount of coffee and with no crema. Is it true that if I ran it with no water it means the machine is broken for life?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
It is likely there’s some air inside the circuit where there should be just water..running the machine while dry might have caused some overheating but I would be a bit surprised that broke it for good. Try running a few coffee making cycles without actually using coffee. If you still have the user manual you may also check what to do before first use and do that again.
Indice 1
Ajouter une réponse
Gabriel sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 6
Total : 205
