Aller au contenu principal
Released in November 2017, the Oppo F5 is the first smartphone to use an 18:9 display instead of 16:9. In spite of having a 6.0-inch screen, the F5's width is similar to the 5.5" display with 16:9. Models CPH1723 and CPH1727.
37 questions Voir tout
Water damaged my phone but I can still hear notification.
My phone is a oppo f9, but i cant find my phone in the listed. I can hear the notifications going off but i cant use the screen. I cant shut down my phone cause shutting it down needs a extra swipe on the screen. What do i do? I’ve tried putting it in rice which helped, the screen was able to turn but after a while it turned off again.
Répondre à cette question J'ai le même problème
Indice 2
1 commentaire
Meri phone Dead ho gah ha f9pro repair Ho gah yah nahi
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hi,
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
Rice is good to eat but does nothing to fix the problems caused by corrosion
Don't Put Your Device in Rice. Here's Why
First do not turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronic parts stores), to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you have to use it check the label to verify the amount of IPA.
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to a video that shows how to dis-assemble your phone which may be of some help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Indice 4
Ajouter une réponse
raycrwong sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 27
Total : 1,508
