Modèles A1237 ou A1304 / processeur 1.6, 1.8, 1.86 ou 2.13 GHz Core 2 Duo
Questions au sujet de 367 Voir tout
Hdd HS12UHEA extract data.
Hi there!!! I have a HS12UHE/A rev. A, i need to extract the data from the hdd and i need a device or something that works with my model of hdd. Thanks in advance.
This is my HDD:
MacBook Air (Late 2008/Mid 2009) 120 GB Hard Drive
Image MacBook Air (Late 2008-Mid 2009) 120 GB Hard Drive
Produit
$89,99
Une réponse ! View the answer J'ai le même problème
Ajouter un commentaire
%Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
Parcourez notre boutique
1 réponse
Solution retenue
Just get any type of external USB hard drive and hook it up. Then either drag and drop your data of for a recoverable hard drive backup, use Time Machine. Here's a plethora of them: http://www.google.com/search?q=external+...
Cette réponse est utile ?
Score 2
Commentaires:
Is not a sata normal device, is a lif or zif pin. Btw the macbook is logic board broken so i can't handle starting it or whatever. Thanks.
par
Dani, there are plenty of Zif-to-USB adapters out there that should work for you. If you take the Samsung model number and do a search for it, you should find what you need. Then you connect it like mayer suggest. You may need a different computer :-) to get to the actual files since your logic board is not working.
par
Is a lif to usb convert i need i guess. I was asking if anybody nows one that actually works!
par
Ajoutez une réponse
Dani sera éternellement reconnaissant.
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,174
