Audio amplifier has short circuit
Hi,I am repairing an audio power amplifier…I don't see any damaged parts but the light bulb indicates that it has a big short circuit…its peavey cs 2000 power amplifier
pls help
pls help
Make, model and a few pictures of the boards inside would help. You give us little to go on here. In general, with a direct short like this, look at the bridge rectifier being shorted (if there is one) or if this has a switching power supply, check the main transistor (should be on a heatsink).
Update this with the above info and we should be able to provide more detailed suggestions.
I am unable to upload images but its peavey cs 2000 power amplifier
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 17
Total : 1,947
Is your amp repaired??
par Mallon Mbewe
Hi im roldan from cebu .my question is..what can i do the speaker out is bad tune ( mahina parang short ,)not fully higher tune.im using 1 channel only cause the other channel is broken .
Thank you.
par Kuya Reinz Bustillo
Hi @Kuya Reinz Bustillo,
What is the make and model number of the amp?
par jayeff
Ask ko lang po kung na short circuit yung amplifier means madadamay po ba yung speaker ? Salamat po
par Michael Geronimo
