Aller au contenu principal
Pour réparer ensemble - Je crée un compte
No water pumping through even though plenty of water in tank
My machine has stopped pumping water through. I can hear the pump working and there is plenty of water in the tank but no water is coming through. Any ideas on how to fix? Or, do you know anyone that would be able to fix?
Répondre à cette question J'ai le même problème
Indice 1
2 commentaires:
I have an older model with the same problem. It looks like a Miss Audrey Rancilio (but without that label).
par
That kind of situation may be covered in the Owners Manual or check their site for a FAQ (Frequently Asked Questions). One thing to note to is, you may hear the pump sound, but that doesn't necessarily clear the pump as functional. May (probably) need to open up the unit for visual inspection.
par
Ajouter un commentaire
1 Réponse
Clogged piping? Could be forcing water through, but not passing. Could also be a bad/damaged pump (motor turns, doesn’t turn pump rotors)
Good luck!
Indice 0
Ajouter une réponse
Kelly Woodward sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 30
Total : 1,045
