Replaced dock connector; cellular not working
I replaced yesterday my dock connector of my iPhone 7. After I installed everyting back together and started the phone, the celullar wasn’t working anymore. It says: No Service. I removed the dock connector, started the phone without any dock connector and the cellular works fine. Is the antenna on the dock connector broken?
Who could help me?
5 commentaires
To be clear: You disconnected the two cellular antennas from the Lightning port assembly and you DO have cellular service, but when those two antenna are connected you DO NOT have service?
par Steve
I only disconnected the antenna cable from the charging port. The cable from the speaker antenna was already disconnected for the testing. So, without the two antenna cables it works but with the cable plugged from the charging port it does not work.
par Uas
Can you post pictures of the connector? Also where are you getting your parts from? I've had this issue before and it was due to a faulty part.
par toreskey
Yeah looks like a faulty part. Basically the antenna on the charging port has a bad connection.
par Ben
@toreskey @benjamen50 I got a new dock connector and still no service. If I unplug the flex from the dock, I got 4G (cellular). If i install the flex from the dock, no service...
par Uas
